Hello, I need help with BJT scheme.
krisio
Joined Sep 2, 2014
1
I've attached an image of what my problem is. The resistors are 10k, 1k, 300 ohms, and Vcc is 5volts. I am being asked what will be Uout if Uin is as shown on the characteristic under the scheme.
dalam
Joined Aug 9, 2014
58
The output will have a 180 degree phase shift as it is Common emitter configuration. Value of beta(Common emitter DC current gain) or hfe is required to find current Ic. Using Ic we can find gm(transconductance). And gain is~= -gm*RL(Load resistance). - sign represents 180 degree phase shift.
ScottWang
Joined Aug 23, 2012
7,501
The circuit is an bjt inverting circuit, so the waveform of Vout(not Uout, V is equal to Volt) will be from +5V to 0V as the square wave.
dalam
Joined Aug 9, 2014
58
How did you determine Vo without Beta ??
I got Vb=2.273 V and Ib=0.1573mA. Without Beta how did you find Ic?
Jony130
Joined Feb 17, 2009
5,598
Are you sure about that result? And we don't need to know Beta here. Because the BTJ will be saturated.
You can prove this by assuming that Beta is larger than 10.
dalam
Joined Aug 9, 2014
58
You can do this by assuming that Beta is larger than 10.
Yes I am sure. Vb(max) = Vin(Max)*10/11 and Ib =Vb/10k.
Even if the BJT is saturated then Vo=5-(300*Ic).
And using KVL : -5+300Ic+0.2(Vce sat)=0
This results in Ic= 16mA.
And Vo= Vce sat =0.2V.
Also BJT does not act as amplifier in sat it is just an switch.
Am I right here?
Jony130
Joined Feb 17, 2009
5,598
