- Joined Jan 23, 2018
- 27,519
3 phase allows two different connection schemes with two different power levels, and neither of them needs a neutral. The Delta arrangement has been already mentioned, but the WYE connection reduces the power quite a bit. The downside of the WYE without a neutral is that the power drops a lot if one leg fails, and if the loads are different then the center is not quite neutral.
