same probleme with me ,i put HCF4017BE instead CD4017 but dosn t work,
You do know they are the same chip, just from different companies. If neither works in the circuit, the problem is probably the circuit.same probleme with me ,i put HCF4017BE instead CD4017 but dosn t work
Shortbus is correct. Unless you have a defective replacement IC, or are running it at a very high frequency. OR, verify that the reset line is low and the clock inhibit line is also low. In addition, I have seen ICs get plugged in with a pin folded under, which will cause strange problems.You do know they are the same chip, just from different companies. If neither works in the circuit, the problem is probably the circuit.
Thanks.@ScottWang, that circuit still leaves the TSOP1738 with excessive supply voltage: when its output goes HI, the voltage on its +Vs terminal will follow, 0.7V above the output voltage, until it approaches the 9V input voltage.
The TSOP1738 data sheet lists its supply current as 0.4 mA to 0.8 mA. With R5 = 820Ω, the resulting voltage drop leaves the +Vs pin with between 8.34V and 8.67V, which exceeds the part's 6V Absolute Maximum Rating for supply voltage.I was calculated the current of Vs less than 5mA, so if the TSOP1738 works as current load then it will be ok, if it is works as voltage load then probably it will be as your concerned and damaged, I think many ee parts(semiconductor) are the current load, so I will treated TSOP1738 as current load.
What your said were about the voltage load, but I'm talking about the current load, I haven't use the TSOP1738, so I can't make sure which one is right, I just according to the experienced.The TSOP1738 data sheet lists its supply current as 0.4 mA to 0.8 mA. With R5 = 820Ω, the resulting voltage drop leaves the +Vs pin with between 8.34V and 8.67V, which exceeds the part's 6V Absolute Maximum Rating for supply voltage.
If use the other IC or device probably that is a easy way, but the problem here is the current limited to too less, so if use zener diode maybe the current will be too much, and that is what the datasheet mentioned.If the TS really wants to use the circuit you posted, he needs to insert a 5.1V Zener diode (1N4733 or equiv.) between the TSOP1738's +Vs pin and circuit GND.
I'm sorry, but that doesn't make any sense to me. Connecting a Zener diode across the TSOP1738's +Vs and GND pins simply clamps its supply voltage to a maximum of Vz; it does not-- and can not-- cause the supply current drawn by the TSOP1738 to increase.If use the other IC or device probably that is a easy way, but the problem here is the current limited to too less, so if use zener diode maybe the current will be too much, and that is what the datasheet mentioned.
What I see is a very real possibility that the voltage at the clock pin never goes low enough to count as a zero. Putting a high impedance meter on it and checking is a good start. Then I am wondering just what the purpose of the circuit is, since it seems that the relay will alternate states on consecutive pulses. That can be done with a CD4013 flipflop just as easily and have an extra one for free. Whit the original circuit and the 100K pull down resistor I doubt that the counter ever saw an input state change, so it would never do anything. I would suggest an input pull-down resistor of 10K ohms at most. Otherwise, just a bit of transistor leakage and the state never goes to zero.I'm sorry, but that doesn't make any sense to me. Connecting a Zener diode across the TSOP1738's +Vs and GND pins simply clamps its supply voltage to a maximum of Vz; it does not-- and can not-- cause the supply current drawn by the TSOP1738 to increase.
Also, I'm not sure what you mean by "voltage load" or "current load." Are you distinguishing between supplying the part with a constant voltage across +Vs and GND, versus supplying it with a constant current injected into the +Vs pin? The TSOP1738 is powered by a voltage across +Vs and GND, like nearly all other ICs in common usage.
As your suggested would be adds one more protection and I re-calculated the values of resistors and redrew the circuit below.I'm sorry, but that doesn't make any sense to me. Connecting a Zener diode across the TSOP1738's +Vs and GND pins simply clamps its supply voltage to a maximum of Vz; it does not-- and can not-- cause the supply current drawn by the TSOP1738 to increase.
What I said that the current load was to described if use the resistor to limits the current less than the rating current and then the load will be no harm, and the voltage load was to described when the voltage exceed the rating voltage then the load could be damaged.Also, I'm not sure what you mean by "voltage load" or "current load." Are you distinguishing between supplying the part with a constant voltage across +Vs and GND, versus supplying it with a constant current injected into the +Vs pin? The TSOP1738 is powered by a voltage across +Vs and GND, like nearly all other ICs in common usage.
Where in the world did you get that idea? If you got it from the data sheet, here:The Is of TSOP1738 >= 5mA
Thank you.Where in the world did you get that idea? If you got it from the data sheet, here:
you need to understand that that 5 mA is a safety rating; it says, in effect, "no matter how you are using this device, do not EVER cause more than 5 mA to be forced into the +Vs supply pin."
Before I draw the circuit, I would like to know what is your best solution to match the voltage and current limitation for this application.That number does NOT tell you the supply current the part will draw; instead, the supply current required by the part is given in the Basic Characteristics section, here:
The TSOP1738 will draw 0.4 mA minimum, 0.6 mA typical, 0.8 mA maximum. That's the amount of current the TSOP1738 will draw at a supply voltage of 5 volts. Not 5 mA.
I would do exactly what I suggested in post #11: use your circuit of post #8, but add a 5.1V Zener diode across the +Vs and GND pins of the TSOP1738 to limit its supply to a safe value.Before I draw the circuit, I would like to know what is your best solution to match the voltage and current limitation for this application.
I would like to see the values of resistors and the current for Vs, Out, and zener diode.I would do exactly what I suggested in post #11: use your circuit of post #8, but add a 5.1V Zener diode across the +Vs and GND pins of the TSOP1738 to limit its supply to a safe value.
That is all that is necessary.
Leave the component values exactly as you had them in post #8.I would like to see the values of resistors and the current for Vs, Out, and zener diode.
