HC74 CHIP Questions
brettsrt
Joined May 9, 2019
50
I am looking to duplicate a board, but i came across this chip which apparently comes in either 3 or 10 pF Input Capacitance, 50, 60 or 80 MHz, and different Max Propagation Delay 15ns, 26ns and 30ns. How can i figure out which one i need?
35,196
We would not know until you tell us the application and the requirements of the application.
I am going to make a guess that any one will do.
What is the frequency of the signal clocking the HC74?
Papabravo
Joined Feb 24, 2006
22,113
I've never heard of digital IC's being segregated by input capacitance for any reason. I'm also quite sure that no chip from the 74HC family will operate at those frequencies. You can check the ordering information in the datasheet to see what the differences are, but they are mostly mechanical packaging and temperature over which the specification are guaranteed to some confidence level.
28,356
Since you are "looking to duplicate a board" you must have an idea as to what you want it to do. Thus you should be able to know what frequencies will be present, and that should give you a good idea as to which IC version to select.
To provide enough information for others to offer better than random guesses you need to provide more context, such as a picture covering more board area, and a description of the function of the board. If you are unable to do that, why are you wanting to make a copy????
brettsrt
Joined May 9, 2019
50
It Is a fiber optic communication board
28,356
Duplicating that board will be a very "big deal" at the least. It is at least a double sided board, quite probably a multi-layered board, with a whole lot of digital logic parts. In addition, U17 and the device to it's left in the picture, with the white covers, are probably programmable devices that may be a serious challenge to duplicate. So unless you have access to a great deal of expertise aside from this site I do not see creating a copy as a possibility.
brettsrt
Joined May 9, 2019
50
This is a 25 year old part that no longer is manufactured, for obsolete equipment for personal use...
I have already successfully programmed duplicate proms etc so i am not worried about that, it is double sided with components on one side, i am going to give it my best try and things i post on here are last few things i need help on and that’s why i do so. You guys are great & i appreciate all your guys help
atferrari
Joined Jan 6, 2004
5,029
Apparently?
It would be simpler if you post the datasheet you have been reading.
Or is it a video in Youtube?
ronsimpson
Joined Oct 7, 2019
4,824
it is double sided
All over the board are capacitor from power to ground. C14 for example. On the other side of the board, are there power and ground traces to each of these or do they connect to a power and ground plane? Trying to know if it is a 4 layer board.
