Has anyone made their own wire connectors?
Riskinit
Joined Jan 28, 2022
65
I want to use this male and female connector in a project but upon receiving some for a prototype I realized I don't have the crimp tool neccessary to accomplish this. Does anyone know how to crimp these? Or is there a better connector I could be using?
Any advice is much appreciated.
dl324
Joined Mar 30, 2015
18,463
Connector in question:
This is the crimper they recommend in the datasheet:
Since the connectors in question use #18-22 wire, you might be able to use this crimper ($15-20 on Ali Express):
I use the largest opening for Molex 0.093" connectors:
Riskinit
Joined Jan 28, 2022
65
Ahhh, for some reason it didn't even occur to me to look at the datasheet for the type of crimper it uses.
I assume I'll need the crimp contacts also if I go this route.
Thank you so much!
SamR
Joined Mar 19, 2019
5,535
They are ~15-17USD on AliX if you can wait a month to get them. I would think the pins would come with the connector. There are also pin insertion and removal tools...
Riskinit
Joined Jan 28, 2022
65
Is AliX a website? What pin insertion tool would you recommend?
djsfantasi
Joined Apr 11, 2010
9,237
For small runs or prototypes with a little practice I could crimp and insert those connectors with small needle nose pliers.
That might you buy a little time before the proper tools can be ordered.
SamR
Joined Mar 19, 2019
5,535
I'm guessing you are referring to Ali Express... something like this?
Yep, but those are just the dies. Once you have the tool you may wish to also get dies for other model pins. Or, splurge and get a tool with complete die set. Should be cheaper than individual dies but may never use some.
Riskinit
Joined Jan 28, 2022
65
I've done it with needlenosers but also messed a few up that had to be redone. But it can be done in a pinch.
I ordered the pins for these particular sockets; should be here in 2 days. I am going to see if I can make the prototype with a cheap crimper at the hardware store. The $670 version is just to do them in parallel so might take me a little longer but I don't have to make ten thousand of these so I'm not gonna splurge on it.
BobTPH
Joined Jun 5, 2013
11,645
I have two crimpers and cannot get consistent results with either. Maybe 1/3 of my crimps seem to be okay. If I use too little pressure, the wire pulls out. If I use too much it severs the wire somehow inside the crimp which is not visible but leaves no connection. If anyone knows what I am doing wrong, please inform me.
Perhaps expensive crimpers apply the correct amount of pressure by using a spring and a stop.
Bob
SamR
Joined Mar 19, 2019
5,535
@BobTPH We just had another thread on this. My crimper has a ratchet and release system. The amount of pressure (release point of the ratchet assembly) is adjustable by a toothed cog on one of the pivot points that has a "fixing" screw between the teeth. There is also on the toothed cog an arced double arrow marked with + & - to indicate more or less release tension. Mine has not been adjusted and is on the last - stop. So all I can do is increase the compression pressure. I think it was a post started by Yaakov about crimpers a week or so ago.
EDIT: Also, note that the jaw dies are one sided, not bidirectional! Plus be sure you have the correct jaw dies installed for what you are crimping.
SamR
Joined Mar 19, 2019
5,535
I also have a couple of long handle ratchet crimpers for larger AWG (up to 6 or 8) crimps and small round crimps. A pair of hex crimpers for coax and a RJ45 crimper for data cables. They are worth the money when you need them.
sagor
Joined Mar 10, 2019
1,055
You could look for inexpensive PA-09, PA-20 or PA-21 crimpers. Each one does different sizes, the PA-09 is the smallest.
That tool does one crimp out of 2 per connector at a time. That is ok if doing a few connectors. You crimp the bare wire first, then crimp the insulation on the second crimp (may be different size). Jaws are very narrow, allowing you to see where the wire is placed before crimping.
If crimping larger pins, then the PA-20 may be a better choice.
28,240
It is possible with many of those crimp terminals to do a fair crimp on the conductors using thin-nosed pliers, and then solder the connection before crimping the tabs down on the insulation. It takes a LOT LONGER and you must be good enough to only get solder into the joint where it is needed. That method can work,but it certainly is slow.
Riskinit
Joined Jan 28, 2022
65
Discussion of crimp connectors and tools:
http://tech.mattmillman.com/info/crimpconnectors/
This was a very informative link thank you. The author brings up a good point that a lot of his connections start failing after 3-5 years which is one reason to get the right tools the first time. I think going with a popular manufacturer might be beneficial for the integrity of this specific product. I think Molex might be sufficient for my needs.
Molex Housing Receptacle Black
Molex Housing Plug Black
Female Contact
Male Contact
Molex Datasheet
My problem once again comes down to the cost of the tool - $370. This is not as expensive as my previous choice but still a tad bit on the high side (40 cents per crimp).
Any specific recomendations for an (almost) equivalent tool for cheaper cost (author used the Engineer PA-09 with some success)?
