Harman Kardon HK3380 Transformer specs
SaileshR
Joined Jan 25, 2021
Hi, this is my first post. I hope I'm in the correct forum.
The primary winding of T102 in my amplifier is open and I've no way of getting a spare. Could anyone please help me with the specs of the transformer:
Secondary voltage -
Current capacity or VA
This would help me in either rewinding the transformer or buying an equivalent in India.
Thank you.
Sailesh.
P.S. The service manual though quite detailed only mentions a part number which is of no use.
SaileshR
Joined Jan 25, 2021
Secondary voltage -
Thank you.
Sailesh.
Sorry, the number should read T602.
Thank you.
35,177
T602 is a low voltage low power transformer that supplies power to the standby and soft power control.
It needs to supply +15VDC after a fullwave rectifier.
I am going to guess about 24VAC 100mA centre-tap.
If you show a photo of the transformer with a ruler for scale we can estimate the power requirements.
SaileshR
Joined Jan 25, 2021
Thank you Mr. Chips. Let me send you a photo. In the meanwhile, here's some additional info, this drives a 5 V regulator (7805), which is used for the standby circuit. Also there's a 12VDC relay, which when Powered, turns the main power transformer On. Circuit attached here too.
