Yes, for this peak in the magnitude of a transfer function. The L1C1 parallel resonance circuit will take responsibility.So the peak of the magnitue curve and the falling of frequency curve must be the resonance frequency of my LC circuit right?
This is not a low pass filter for sure.As far as I could see this circiut is a low pass filter. Because low frequncy can pass, and high frequceny is going be filtred. But please correct me if I am wrong.
Well, the resonance is the problem. Simply plug the s = i/√(L1 C1) into the transfer function and should be able to see the problem.In other word. What kind of a problem is resulting with that frequency for my circuit?
About what?Does no one got an idea ?
Why don't you just "plug" this into the transfer function and see by yourself what you get?1.) What is the behavoir of G(S) the transfer function for S-> 0 and S- infinity ?
So you want to calculate the L1 value based on the circuit time constant?2.) The time constants T1 from L1, C1 and T2 from C2, R2 are the same size and the capacitances C1 = C2 = C are also the same. What does this mean for the inductance L1?
Yes I know but I was confused because of an other post of you. (I'm not lazy, I'm just unsure about.)Why don't you just "plug" this into the transfer function and see by yourself what you get?
And when I insert s- > 0 and s - infinity I get something which doesn't compare, with that you said here.But we can answer this just by looking at your circuit. We don't need to know the transfer function.
For s -> 0 we have Xc = ∞, XL = 0Ω
and for s ->∞ we have Xc = 0Ω, XL = ∞
Yes you got it. This is what I want to calculate.So you want to calculate the L1 value based on the circuit time constant?
Show me what doesn't compare with what I saidAnd when I insert s- > 0 and s - infinity I get something which doesn't compare, with that you said here.
So, what is the problem?Yes you got it. This is what I want to calculate.
I don't know where to start. Because I don't have real values. That makes it complicated for me.So, what is the problem?
If you don't know how to take "limits" in math. Then try to analyze these two equivalent circuits
\[ \tau_1 = \sqrt{L_1 C_1} \]
\[\tau_2 = R_2C_2 \]
| Thread starter | Similar threads | Forum | Replies | Date |
| T | I can't calculate internal resistance of my batteries to match measured | General Electronics Chat | 46 | |
| H | How to Calculate LDO Input Current for Battery-Powered Application? | Analog & Mixed-Signal Design | 2 |
