Hard Wiring Audio channels
Daan Lageschaar
Joined Jul 8, 2019
45
Hi there,
I want to hard wire 2 audio sources together and only have one of the grounds connected using a 2 way sliding switch (attachment) Will this work or will this do some weird things? The 2 ground wires aren't connected together in any way, one of them leads to a usb bluetooth reciever and the other one leads to a high level to low level audio signal converter.
Thanks in advance,
Audioguru again
Joined Oct 21, 2019
6,826
Your idea of switching only the grounds will probably case severe interference from the 50Hz or 60Hz electricity sprayed from electrical wires in the walls around you.
28,345
In every audio source the signal and ground conductors are connected to each other by the source impedance. Thus, by having the signal lines all joined and opening the shield connection pf one you would be tying the shield to the signal line through the source impedance. That would certainly add a whole lot of noise, mostly the AC mains hum pickup.
Why even consider switching shields and not the signal side of the connections? I am wondering what led to considering that option.
Daan Lageschaar
Joined Jul 8, 2019
45
Well I'm building a little amp box using a pre assembled AliExpress amp, which I'm also going to put a Bluetooth module inside of, and since the sliding switch I had lying around has 6 poles (basically the one in the picture but just 2 of them together) I wanted to make the Bluetooth module turn off while I'm not using it, I thought I could use the other 'lane' (or whatever it's called) on that switch for cutting off the power to the Bluetooth module
28,345
It is OK to wire the audio signal commons together and only switch the signal lines, and that would give you the other side of the switch to control power with.
In addition, multi-pole multi position slide switches do not cost very much from some sources. So that is a cheap option also.
Daan Lageschaar
Joined Jul 8, 2019
45
You mean wiring the left and right channels together?
28,345
I mean the SHIELD side of the audio signal pair. NOT the signal side of the pair. AND if you are talking about SPEAKER connections, that is different yet. Some amplifier circuits us an arrangement that does not allow speaker leads to be connected to anything besides speakers. That is often described as a bridging output, or a bridge output. It is a differential output in technical terms.
Tying stereo signal left and right to make a mono signal often requires adding some resistors to provide some isolation. Not a big deal but usually it should not be ignored. Possibly some audio wizard here can draw you a circuit showing how to do that.
Daan Lageschaar
Joined Jul 8, 2019
45
Sorry for my late reply,
I'm definitely not talking about speaker connections, just low level audio signal stuff. But I guess I'll just leave the bluetooth module on all times then
28,345
OK, I was just presenting a caution in case it was speaker connections. Input signals are different, and now it appears that the amplifier is a stereo amp and the radio signal is a stereo signal, and so to switch them and also switch off the bluetooth module you would need a 3-pole switch with 9 terminals, or possibly two switches. I will need to think a bit and see if there is a way to do both with the switch that you have.
OK, here again is the description of the sources. "one of them leads to a usb bluetooth reciever and the other one leads to a high level to low level audio signal converter. " OK, now I have an idea, and a question: Does that high level to low level converter use any power? Does it include any active devices such as transistors or ICs? If so, does switching off it's power stop the output to the amplifier?
My reason for asking is that if both devices "go quiet" when switched off then the solution could be to connect them both at the same time using a simple passive fixed mixer circuit, and just switch the device power. So now the answer to the question could enable a simple solution.
Daan Lageschaar
Joined Jul 8, 2019
45
nope, it's not powered unfortunately
28,345
OK, now an interesting possibility would be to add an analog buffer IC to that line and then switching would all be done at DC levels. A fair amount more complex, but it would work. OR you could use an analog switch IC such as the CD4066 to do the switching. More complex but another compact option.
Another simpler and cheaper idea popped into my head, which is to use diode switching. Simple, cheap, and easy, and it would allow switching the blue-tooth module on and off. Sorry I did not think of that earlier.
