Hard to read markings on chips
SamR
Joined Mar 19, 2019
5,039
Seeing the stereoscope in the dream bench photo started me thinking. I really need one since I have a terrible time reading the markings on some chips. And I came up with an answer. Photograph it and zoom in w/ photo editing software.
Ya’akov
Joined Jan 27, 2019
9,143
An enhancement to that idea. Click on the second attachment to see the effect.
The laser etching used on many SMD parts can be very hard to read. For those that refuse to give up their secrets even under varied lighting and magnification, I have a trick that usually works quite well. All you need is a regular fluorescent highlighter pen and a UV light.
Run the highlighter over the part, as if highlighting something on a page. Then, wipe off the surface with a dry wiper or swab.
The ink retained in the etching will fluoresce more than what remains on the surface, revealing the part number in (relatively) easy to read illuminated lettering. If you desire it, some isopropanol can clean off the ink, but it's probably not required.
This has helped me in the past, I hope it can help someone else.
bertus
Joined Apr 5, 2008
22,276
I also think it is the NE555.
Do you have a flatbed scanner?
I made a scan of two chip I had laying around:
Can you read those?
bertus
Joined Apr 5, 2008
22,276
Can you see the production dates?
In that time there was no laser marking, but printed markings.
One chip has a plastic case, the other a ceramic case.
SamR
Joined Mar 19, 2019
5,039
Can you read those?
It is the 555 and almost impossible to read even with my gooseneck LED magnifier. I've wiped them, wetted them, used the gooseneck plus another magnifying glass to increase the magnification, turned them all directions trying to get a good light angle on the markings and this beats them hands down for me using what I already have.
Yep, most printers have scanners now. Another good idea, but those chips look well marked compared to the ones I have trouble with. I'll try that next time I have trouble and thanks for the tip.
Wolframore
Joined Jan 21, 2019
2,610
I recently got a couple MPU9250 and 6050 gyroscope chips... the markings were so tiny I could not for the life of me read them... 4 lines of markings on a tiny QFN package... my son had to decipher for me.
This is what it looks like to me:
This is what's there:
pmd34
Joined Feb 22, 2014
527
Hmmm yes, and thats while the packaging is still big enough for a couple of letters, many SMD components now just have a couple of meaningless letters or numbers, almost impossible to trace even if you can read them!
Alec_t
Joined Sep 17, 2013
14,313
For laser-etched markings, try smearing toothpaste or similar white goo over the surface. It fills the etch valleys and makes the marking distinct.
SamR
Joined Mar 19, 2019
5,039
I don't have the UV lamp (haven't used an EPROM eraser since forever), but am adding it to the Wishlist now.
Ya’akov
Joined Jan 27, 2019
9,143
You can get a cheap UV flashlight, it is also useful for curing UV adhesives and resins. Only a few dollars for a totally functional one.
SamR
Joined Mar 19, 2019
5,039
Yaakov said:
Run the highlighter over the part, as if highlighting something on a page. Then, wipe off the surface with a dry wiper or swab. The ink retained in the etching will fluoresce
I just tore down several breadboards that had impossible to read chips. Did this and it works much easier and quicker than my photo and zoom method. I ran a yellow highlighter over them and didn't wipe them before flourescing. Works perfectly. Kudos to Yaakov!
Ya’akov
Joined Jan 27, 2019
9,143
Glad it proved effective. I struggle with markings sometimes.
