Half wave rectifier
Pickles
Joined Mar 13, 2015
29
Good evening,
I am trying to complete some questions and I am struggling to understand what they are asking for. I have answered the other questions already but I'm not sure about these two.
The questions are:
Observe the traces of the input and output signals and comment on your results.
What is the average value of the input and output signal.
(Is this one asking for the average value of a sine wave?)
Below are the two images with it.
Many thanks
34,809
The question asks for the average value of
1) the input signal
2) the output signal
How does one compute the average value?
You take the sum of N samples and divide by N.
For periodic signals, make sure that N samples fall within integer values of the period of the signal.
It is ok if the integer value = 1, i.e. sum over one period.
Do you know calculus?
dl324
Joined Mar 30, 2015
18,326
Since this is probably homework, what can you say about the signals?
It would seem to me that the question is also referring to the output waveform.
SamR
Joined Mar 19, 2019
5,487
#1 Draw the signals for the supply V
#2 Draw the signal for the output V
#3 How do you calculate the average V for each signal???
It's pretty basic AC sine wave calculations that can be easily done without calculus... Although it was derived from calculus...
27,511
This looks like homework. The blue trace is the supply V voltage, the red trace is the waveform of the output V.
The formula for calculating the average value of a sine wave is tedious to derive.
27,511
But to derive it, you need to know calculus, right?
It was derived in my calculus class back in 1971, I recall. The solution for the relationship between the peak, RMS, and average voltages of a sine wave is just a simple numerical ratio multiplier. That number is easy to look up and use.
Pickles
Joined Mar 13, 2015
29
Ok thanks everyone. To work out the average value of the input and output signal would you use this equation...
Many thanks
Pickles
Joined Mar 13, 2015
29
And what happens to Vp after it crosses the diode?
Sorry I am really struggling with this. The notes we have been given don't explain anything.
Does any one know of an online circuit making website that I can build this circuit and see what is happening in it?
Pickles
Joined Mar 13, 2015
29
1) the input signal
I don't understand were you get any values from to work out the average.
Yes I can do Calculus.
