Half bridge with bootstrap
REHAM RAMADAN
Joined Mar 26, 2016
How to test the low side mosfet by making the high side mosfet off with the schematic in picture using an Ic of bootstrap?
I am asking because i have a short circuit and I don't know why
JUNELER
Joined Jul 13, 2015
183
You cannot test only the low side ,its a complementary of the other.
Since this is an IC, direct replacement the least you can do.The cause of the short circuit depends to your load.
REHAM RAMADAN
Joined Mar 26, 2016
I am connecting my load between the low side drain and the 20v supply to the inverter. The load is a 22 ohm resistor rated 25 watts.Is this connection ok ?
