Hair clipper wont charge higher capacity battery?
Tom_37
Joined Sep 30, 2020
13
I replaced the two 750mAh AAA batteries in my hair clipper with two same type but 1100mAh batteries and they wont charge. Is is because its higher capacity?
peterdeco
Joined Oct 8, 2019
484
This is unusual. Rechargeable devices such as my electric drill and previous cell phone had higher capacity battery packs available for extended usage. As Keith said, check the charger.
Tom_37
Joined Sep 30, 2020
13
I replaced with the old ones again and still charging but not with the new batteries.
Alec_t
Joined Sep 17, 2013
15,156
Are the replacement batteries of a reputable brand from a reputable source, or could they be fakes/rejects?
Can you measure the actual new battery voltages? If they're too low, the charger might take objection and refuse to charge them.
Tom_37
Joined Sep 30, 2020
13
They are slightly used gp batteries. I charged them with desk charger and they have good voltage.
BobaMosfet
Joined Jul 1, 2009
2,211
And you made sure the replacement batteries are rechargeable? They won't overheat and explode or some other nasty thing? Do you know anything about your charger? if the higher rated batteries output more current than the charger can overcome.... that could explain why it isn't charging.
Tom_37
Joined Sep 30, 2020
13
Yes they ar rechargable.
How do I know current rating and why does it matter?
Audioguru again
Joined Oct 21, 2019
6,826
Look at the website of GP batteries. They do not make 1100mAh AAA Ni-MH batteries so yours are probably fake ones.
GP Battery company is Chinese anyway. Buy name-brand batteries from a Western company instead.
BobaMosfet
Joined Jul 1, 2009
2,211
Here is a datasheet example for an AAA 2 1100mAh:
Your charger can't charge everything- it was _designed_ to charge a specific sized battery, based on the output of the battery it expects to charge. If it isn't able to handle a higher capacity battery, it's because it can't output enough current and voltage to overcome the battery (it's arm-wrestling with the battery to charge it).
BobaMosfet
Joined Jul 1, 2009
2,211
@Audioguru While I respect you tremendously when it comes to electronics knowledge, I am irritated by the constant knock against Chinese electronics. China makes a lot of excellent electronic components. In fact, they supply the world with the majority of electronic components (out of Zhenzen). Many of the components out there, you can't even acquire unless you by from China, or you can't acquire them at a decent price. I source components from 70+ countries around the world, hundreds of thousands of parts a year. I find the Chinese parts in most cases to be excellent, reasonably priced, and they are big on service and ensuring you're happy with the purchase and quality of components. Displays, motors, semiconductors, passives, actives- everything you can think of, I purchase in quantity.
In the end, buyer beware, and must do due diligence, but painting Chinese electronics all with the same brush is unfair. IMHO.
Tom_37
Joined Sep 30, 2020
13
That explains it. Thank you.
