Hacking automatic air freshener.
taith
Joined Apr 1, 2017
28
So I bought that air freshener purely for other purpose, however timer is way too fast for me, is is there some way to slow it down? I'd assume changing some resistor values.
RichardO
Joined May 4, 2013
2,270
You may be in luck. I don't see any epoxy blob or parts with a lot of pins. :D
There are only 2 capacitors. I am guessing that increasing the value of one of those will increase the time. The other parts may limit how long the time can be.
Try reverse engineering the circuit and post your results here for a better answer.
taith
Joined Apr 1, 2017
28
In this photo I tried to make all writings visible, chip have no readable markings.
Measuring these caps without desoldering will be accurate?
I have multimeter capable of measuring on board.
