Hacking a flow sensor - Hall Effect Sensor help
marsrovers
Joined Sep 16, 2017
12
just to finally document incase someone at a future date is looking to see the conclusion of this thread:
Neptune Systems FS-100 flow sensor:
hall sensor output >> internal red wire >> 3.5mm plug tip
hall sensor V+ input >> internal green wire >> 3.5mm plug lower ring
hall sensor ground >> internal black wire >> 3.5mm plug Sleeve
Reloadron
Joined Jan 15, 2015
7,978
Yay, it works. Now that you should get pulses for flow you can work on the K-Factor I mentioned earlier. Looking at the data sheet, what I could find anyway for the whole sensor I saw no mention of Pulses for unit of measure for example pulses per liter or gallon. That will figure into your code you write.
Ron
