Hello i have been working on h bridge for awhile its my 1st design as you see below
using it to control 14amp rater 24 volt (250 watt) motor
controlling using Arduino (500hz frequency )
(1-0) move in 1 direction
(0-1) other direction
(1-1) Break
the upper side is P channel IRF9540 or 9540N i used both
http://www.irf.com/product-info/datasheets/data/irf9540n.pdf
the lower side is N channel IRF540 or IRF540N also
http://www.irf.com/product-info/datasheets/data/irf540n.pdf
for level shifting ( 5 to 12v)
im using BC547 NPN
http://www.futurlec.com/Datasheet/Transistor/BC547.pdf
to keep the voltage (VGS and VSG ) for P and N transistors
im using 12 v zener
here they name it only by voltage and wattages
im currently using 1 watt zeners
the max available is 5 watt
R zener is 1k in case its not obvious enough !
the driver works fine without loading
but if i add them my sort of cart project
15k load
the motors dont seem to move the transistor HEAT AND HEAT then they blow !
can you guide me whats the problem
sorry for the long post ,just hoping for help asap !
Thank you to infinity
(1-1) Break
im using BC547 NPN
im using 12 v zener
15k load
