Ok. Thanks for the photos. Those will do for now.
It looks like you have some work ahead of you. You will have to remove the top board in order to get access to the bottom board. This means firstly removing the control knobs and then the retaining nuts that hold all the jacks and controls on to the front panel, also the two screws holding the BALANCED LINE OUT.
Before you go ahead and do that, turn the MASTER VOLUME to 0 and describe as best as you can the noise you are hearing.
