At this point, it doesn't matter. It is really hit and miss as long as you have a consistent plan and procedure.When the amp is noisy with nothing plugged in and all the volumes at zero, would a person normally start testing from the output to the input, or does it matter?
What do you mean by:Two tests I've done: 1. On the cement resistors that looked cracked to me and maybe failing. Here were their readings = 330ohm A-Pair 1 17.1v and 46.0v * B-Pair 1 = 46.0 and 17.1v. On Pair 2 and Pair 3 zero volts. ~ Another test I went back and did = plugging in a guitar cord
to where the amp would output to the speaker, I checked for any voltage at the tip of the plug and it measured 0.27v on the 2volt scale. This is the noise that is heard when the amp is switched on with all levels at zero.
The thump you hear on turn ON and turn OFF is normal.Maybe also the 2 big caps that I had thought tested good are releasing and that is why there is also a pop thump when I turn it off and it is hooked up normal to the speaker. As I wrote down they read 4726uf and 4709uf (4700uf 50V). Thoughts?
Nothing unusual you have reported so far.Unless I am testing wrong TP2 has zero volts on both the little mustard cap and the diodes around it. The 8th leg on the IC 1B checks 15.1v
If that is correct, then we are getting somewhere.Removed the 5 pin connector and jumped 2 to 3 = thump on activate but the speaker is quiet after that.
I will assume that you jumpered the "wrong" end of the connector. But that's ok. It still gives me some useful information.No, I disconnected the 5 pin connector and then I made a jumper with 2 crimp fittings and pushed them over those two pins. The 5 pin was just hanging off to the side.
