MisterBill2
- Joined Jan 23, 2018
- 28,272
WHICH RESISTOR BURNED UP?
Also, I see three BE voltage drops between the bases of Q4 and Q6, so either a diode is missing or one of the diodes is not a 1N4148. That is a puzzle indeed, as most amplifiers include diode drops to match the B-E drops in the output section. But I also see only 2 diodes in the photo, so it does seem a puzzle indeed. If R19 burned, it was because of no base current drawn by Q7 otherwise there should only be one B-E drop of the output transistor across R19 and R20.
So both driver transistors were turned on solidly. That points at Q3 being either shorted or driven into high conduction for some reason.
Direct coupled amplifiers are SUCH a pain to analyze when things go wrong!!!
