Guessing Pulse Transformer Turns Ratio
alfred75
Joined Feb 7, 2013
Hi guys! Is it possible to determine the turns ratio of a pulse transformer by looking at its inductance (H) values?
I'm trying to find the replacement of the faulty transformer but the part number is really blur, it's impossible to read it. It is used in the servo drive and serves as isolation transformer to fire the IGBT.
Thank you in advance for your advice!20191009_094202.jpg 20191009_093607.jpg
38,781
The inductance is proportional to the square of the number of turns so the turns ratio would be equal to the square-root of the inductance ratios.
Thus for the measured values you show in the picture, the turns ratio would be √(47/0.87) = 7.35:1.
eetech00
Joined Jun 8, 2013
4,724
HI
You can use a sine wave signal generator and input a 1v rms signal in one side of the transformer and measure output on the other side.
For example, if the ratio is 7.35:1 (pri=7.31, Sec =1), input 1vrms into the secondary and measure the primary. The primary should output approx. 7.35 vrms.
eT
38,781
I would suggest a test frequency of at least 10kHz and an input of 100mV to minimize the chance of saturating the core.
alfred75
Joined Feb 7, 2013
I found the turn ratio is about 1:1.7 by experiment with the generator signal.
It's same as the theoretical value of sqrt(2.47/0.87)
Thanks everybody
