that title is quite a bit clunky, hope I'll do better job explaining what my problem and requirement is here:
I have a circuit that has two PSUs: one for MOSFET driver chip (PS2); one for Raspberry pi (like) board (PS1).
The driver is driven by the LTV-3120 driver which has it's input opto-isolated.
The driver needs to have common ground with the MOSFET hence GND is connected to the minus terminal (pin 4) of the bridge rectifier. + 100KΩ pull-down resistor between Gate and Source.
![1685696544665.png 1685696544665.png](https://forum.allaboutcircuits.com/data/attachments/283/283166-c56ce26569545690eae18801fb364ae0.jpg)
function-wise it works, BUT:
PSUs are leaky; a few mA but it leaks 220VAC phase to the it outputs so to NOT to have and operator electro-shocked while connecting sensors to the exposed GPIO pins (J1, J2, J3, J5) I have earth grounded negative terminal of PSU1 (GND1) which solves the issue of electro shocking. I don't think it's an go-forward advisable solution through I know this earth should be screwed on device's chassis.
So, hope you get the idea now and can be helpful with solving the grounds/earth problem now so this can be production ready soon.
Thanks for all suggestions!
