Ground terminal on Power Supply output
Martino Chiro
Joined May 1, 2015
128
Most DC power supply have a ground terminal, as shown here, but what is its function ?
Are there any cases in which this ground connection is mandatory ?
Thank you.
Papabravo
Joined Feb 24, 2006
22,111
If your power supply is powering a device with a metal chassis, you want that chassis at ground potential for safety. If there are no exposed metal parts then you don't need to worry about it.
Martino Chiro
Joined May 1, 2015
128
Thank you Papabravo.
But this is true also for low voltages as those generated by a 0-30V dc power supply ?
DickCappels
Joined Aug 21, 2008
10,661
If you are working on circuitry powered by in addition to or apart from the bench supply, you can use that connector to ground the chassis so you will not be tickled or injured by AC leakage to the chassis.
PhilTilson
Joined Nov 29, 2009
155
I use the ground terminal on my PSU to connect my anti-static mat. That way, I know I am unlikely to fry any static-sensitive components that I am working with, even when the boards are powered on.
Delta Prime
Joined Nov 15, 2019
1,311
Did you happen to take a peek at the link it's a very good read. It compliments and supports the information these good gentlemen have offered! :)
quoting post #7 of the link provided. I've no comments just yet, but earth, ground, and common are about the three most misunderstood words in all of the electrical world.
This discussion should be an eye opener.
Martino Chiro
Joined May 1, 2015
128
Very interesting link, I agree.
