Why not.cant use Opto Isolator
This circuit works very well when one part is taken.Why not.
That's the obvious solution to your problem.
So are there any other isolation methods you can't use?
Plus Hall-effect device to measure the current.Opto Isolator for Mosfet Q1 common
Why won't you answer the question? Why is using an opto-isolator on Q1 "not possible"? It beats driving the gate of that MOSFET with a wimpy opamp like the LM324.This circuit works very well when one part is taken.
The system works very well when all ground are connected.
This system is flawless.The current controlloing is very smooth and stable.
The current flowing through the shunt could also be measured very accurately.
So there are no errors in it,
I took the help of EEv bolog, Greatscoot, electronoobs YouTube channels for this. There are no errors. But
this circuit has 3 main units
1) esp32 DAC --> non inverting amp gain is 4 (12 V DC )
2) current control loop (185V DC )
3) measure shunt voltage --> non inverting amplifier to gain 6 ( 3.3V DC) --> esp 32 ADC
These three sections are powered by under different voltage levels! I want isolate Grounds of 12V and 185V for safety.
Is it possible to use ground isolation like B1212 or any other method for this ?
how to use optocoupler/opt isolator for DAC output and current measuring ADC input ?
You still have not answered the prime question which has been asked of you. Way can't you use an opto-isolator? You have flung a torrent of irrelevant material against the wall to see if anything sticks. Your obstinate refusal to answer that question will inhibit the quality of the advice you receive. That said I will answer the question that you posed.
by Jeff Child
