Grid-Capacitance Linear Synchronous Sensor
Benjamin Neil
Joined Mar 29, 2019
Essentially, I want to build a scaled up caliper; its is an instrument for measuring the length of bones, the analogue version looking like the picture (here: http://www.aylj.com/en/expertise_stator.htm). I have seen a homemade digital variation of this, so know it is possible to make.
The picture of the PCB is showing both sides of the board.
If I were to make a one off, I would probably buy a vernier caliper, tear it down for the PCB and try and find a 'cut to size' stator grid. However, there is a possibility of making a few, so if possible would like to find a supplier.
Ya’akov
Joined Jan 27, 2019
10,291
I would suggest you look into inductive linear sensors used in industrial automation. Very accurate, if not cheap, and with various ranges.
https://www.zettlex.com/products/oem-linear-position-sensors/
There are also pre-packaged versions which might be useful, just search around.
28,133
The second question is how accurate do you need to be? Range, resolution, and accuracy are the three parameters that tell if you need a micrometer or a yardstick.
