Gravitational waves confirmed...
Sure you can: drop a piano on someone's head. ;)
Energy is stored in the gravitational field, though it's many orders of magnitude weaker than the binding energies of the nuclear fields.
Still not a 'bomb'.:D
You can transmit gravitational energy as a possible weapon of destruction using a gravity field if the curl of the vector field is not zero across the object. It's just not something you can easily carry like a bomb because it requires massive objects moving rapidly closely like neutron stars or black holes in a death spiral.
Yet supernovae are the biggest 'bombs' in the universe.
Sure, the gravitational potential energy is converted into kinetic energy in a Core collapse supernovae but its the nuclear force (neutrino generation) that makes the bomb effect possible as the Coulomb barrier is broken.
visionofast
Joined Oct 17, 2018
106
well,I think studies about the origin of gravity wave could be useful only if it leads to know a more powerful force than nuclear power...to use as bomb or as a new propulsion.otherwise it doesn't make sense.
anyway ...for misusage of newly studied physic (or even metaphysic) rules,there seems to be always ready syndications watching our minds :\
https://www.ligo.caltech.edu/mit/news/ligo20190214
"This award ensures that NSF's LIGO, which made the first historic detection of gravitational waves in 2015, will continue to lead in gravitational-wave science for the next decade," said Anne Kinney, assistant director for NSF's Mathematical and Physical Sciences Directorate, in a statement. "With improvements to the detectors—which include techniques from quantum mechanics that refine laser light and new mirror coating technology—the twin LIGO observatories will significantly increase the number and strength of their detections. Advanced LIGO Plus will reveal gravity at its strongest and matter at its densest in some of the most extreme environments in the cosmos. These detections may reveal secrets from inside supernovae and teach us about extreme physics from the first seconds after the universe's birth."
cmartinez
Joined Jan 17, 2007
8,896
cmartinez
Joined Jan 17, 2007
8,896
cmartinez
Joined Jan 17, 2007
8,896
cmartinez
Joined Jan 17, 2007
8,896
https://iopscience.iop.org/article/10.1088/1475-7516/2020/09/022
The LIGO/Virgo collaboration have by now detected the mergers of ten black hole binaries via the emission of gravitational radiation. The hypothesis that these black holes have formed during the cosmic QCD epoch and make up all of the cosmic dark matter, has been rejected by many authors reasoning that, among other constraints, primordial black hole (PBH) dark matter would lead to orders of magnitude larger merger rates than observed.
cmartinez
Joined Jan 17, 2007
8,896
[]... scientists predict that there is also an ambient murmur of subtle, low-frequency ripples constantly flowing through everything in the universe, including Earth. Now, researchers think they’ve found a candidate signal after more than a decade of watching fast-spinning collapsed stars for the faintest sign of a discrepancy that might indicate a wave.
