Hello all, new member here!
when I was a child I owned a game released by Grandstand in the UK called 'Astro Wars' (also known as 'Galaxy II' and released by Epoch in other countries).
It was awesome, at least that's my recollection of it, but unfortunately the unit I have no longer works and so I have been trying to repair it, and I was wondering whether any of the kind folk on this board would be interested in helping...
This is what I'm talking about!
After spending quite a bit of time on this I have narrowed down the faulty component but I have been unable to identify exactly what it is, so I'd appreciate some advice.
With no circuit diagram available I had a go at creating one (see attached) but I can't guarantee it is correct, although maybe it'll help see what the component might be doing. I'll add some description below.
The faulty component is S06 (bottom centre of the schematic), and I have confirmed this by obtaining a working game and taking the S06 from that unit to repair the faulty unit. With that good S06 in place the broken unit works perfectly. Obviously to get the faulty unit working I need to find a new S06 for it.
You can see the component below (this was taken during testing, which is why one leg is detached).
The circuit takes a 6v input and produces a -10v supply for the microcontroller and -39v to drive the VFD display.
Pink voltage values in circuit have been measured in the working unit.
With the broken S06 in circuit I noticed that the Transistor (S02 - a D882 npn transistor) gets very hot very quickly when power is applied. When switched on the voltage (when measured at the supply) drops to around 2.5v and the current is high - 1.5A(!). The game does nothing - appears dead.
When S06 is removed from the circuit, all voltages on the board are as expected (except -39v VFD voltage is not present), and the microcontroller is working. I provide a separate dedicated supply to the VFD I can see the game is functioning correctly.
I have checked all caps, confirmed operation of all transistors, confirmed all resistors. S06 is definitely the problem.
The component looks (to me) like a diode (see picture above) but when removed from circuit the faulty S06 measures 20ohms in either direction when measured with a DVM - not typical diode behaviour. The working S06 acts like a typical diode when tested in the same way.
I first though this component was a 39v zener diode based on my observations below:
The cathode of the S06 (assumed 'diode') connects to pin1 on the transformer.
I disconnected the other end of the diode from the circuit to see what's going on here.
I was surprised, but I'll report what I saw. Keep in mind I have only a basic handheld scope and it may not be correct.
The Transformer is providing an ac signal, 200v pk-pk, period 10us, -140vdc offset to the cathode.
At the anode, which is disconnected I see a -39v dc signal with only minor ripple of 1v pk-pk.
I ordered a 39v zener and installed it but the game still did not work, the D882 transistor got very hot, very fast. Unit is dead. Hmmm.
Next I connected five 9v batteries in series with a resistor as a simple circuit to test the known working S06 component to confirm the zener voltage but that appeared to confirm this is NOT a 39v zener diode after all. The component did not clamp the voltage when measured across it with a DVM...
Can anybody add any insight into this problem??
I'm quite determined to get to the bottom of this but have run out of ideas....
