Gra&afch nixie tube problem
JakeLumpy
Joined Aug 10, 2020
5
I recently put together a gra and afch nixie tube clock kit and everything works fine except that whenever the 1st digit in the groups of 2 tubes is a 5 every digit in those 2 tubes lights up. I figured there was a short in the HV5122PJ chip but I resoldered it and I am still having the issue.
bertus
Joined Apr 5, 2008
22,995
It looks like leakage of currents, as more numbers in the same nixie are activated.
It can be there is a problem with the nixie driver.
Bertus
BobaMosfet
Joined Jul 1, 2009
2,211
IMHO I would actually suspect a logic error, or code got corrupted during transport in the MCU, before I'd think hardware, based on what you've shown/described. Can the clock be reflashed remotely?
JakeLumpy
Joined Aug 10, 2020
5
I believe it can be reflashed. I’ll look into trying that.
Just finished the exact same clock. I would check to see if some of the pins on the back of "NX1" are touching the top of one of the two large caps. This allows a short between two pins and results in two or more characters to be lit at the same time. I had the same problem and removed some of the height of the pins on the back of "NX1" so no contact is made between the pins and the top of the caps. then used a small round disk of electricians tape to insulate the top of the two large caps. I had the 2 and 4 showing at the same time, this should fix your problem. This is kit has some got yah's along with a few other issues. Hope this helps.
JakeLumpy
Joined Aug 10, 2020
5
I did have an issue with that as well I just placed some insulating tape on the tops of the capacitors so the pins wouldn’t make contact.
28,127
Bertus
Burtus is on the right track. If it is not a logic error then it would be leakage, either inside the tube or in the associated circuits. So the first thing is to exchange tube positions and see if the problem stays in the same position, or follows the tubes. Neon indicators are quite high impedance devices and so it may be that the resistor array associated with those sockets are incorrect.
