Good Sine wave amplifier
MrAl
Joined Jun 17, 2014
13,793
Are you sure that 9V is the real limit for that scope?
I have a real cheap scope that only takes about 5v max input (or something like that) with a 1x probe, it runs off of a 9v battery and the main IC chip is just a 5v microcontroller. Max sampling speed is 1 megasamples per second. A 10x probe takes the max input up higher.
Most 'real' scopes go much higher than that though even with a 1x probe.
atferrari
Joined Jan 6, 2004
5,029
Sorry MrAl but your reply seems not answering, replying, explaining, justifying the limitation allegged by the OP.
Guessing if his not thinking of a maximum voltage for the PSU. Note I said, guessing.
Sincerely, BTW, he seems to have not very clear what he could / need to do, to implement a project not yet precisely defined.
MrAl
Joined Jun 17, 2014
13,793
There was a question of what scopes can do as to the input range so i thought i would mention one that had a very limited input range.
