lm741 help -- Sine wave amplifier
Zeeus
Joined Apr 17, 2019
616
Tried to do this..no knowledge on op amp..will read AOE but just decided to briefly visit an old circuit from a beginner book (Electronic circuits for the evil genius)
Wrong? :
Since feedback is applied, input to inverting is 4.5V which is equal to output voltage
It checks out with multimeter but now when I connect function generator (without turning it on) to capacitor, the input to inverting goes down thereby taking output close to 9V (How to fix?)
To fix, figured needed to add pot on offset pin, it worked at first : the output was close to 4.5v..When I applied sine wave input though, the output was an attenuated sine wave
I was expecting to get (100meg/1k) inverting sine wave gain : guess this should be the answer if input to non inverting is 0V but from the book and spice, seems the right answer should be a square wave
someone please enlighten me
AlbertHall
Joined Jun 4, 2014
12,652
What type of capacitor did you use for C2?
If you used an electrolytic then that is probably the problem. The leakage current of the capacitor must flow through the feedback resistor and as it is a very high value will mess up the DC voltages.
In the simulation, add a resistor across C2 to represent the leakage resistance. With 10MΩ the DC output rises to 8.09V
Zeeus
Joined Apr 17, 2019
616
Thanks...C2 is input cap..changing it to 0.1UF gives square wave output and dc output is 4.5v
but using this small cap puts f3db high? (guess to adjust R4)
"add a resistor across C2" : in parallel? Tried it, output about 8v like before
"The leakage current of the capacitor must flow through the feedback resistor and as it is a very high value will mess up the DC voltages." Every capacitor does this?
AlbertHall
Joined Jun 4, 2014
12,652
Different types of capacitors have different leakage currents and electrolytics are worst. You should be OK with ceramic or film capacitors.
Doing this in the simulation (definitely not in the real circuit) will show you the effect of the capacitor leakage current on your circuit.
bertus
Joined Apr 5, 2008
22,998
Reading the datasheet, the LM741 needs at least ± 5 Volts.
Even then the output swing is minimal:
Also it will not be possible to create a gain of 10000 on 1 kHz as in your schematic.
The GBW is only 1 MHz.
Bertus
Zeeus
Joined Apr 17, 2019
616
Bertus
The output is not a sine wave as expected by me..was just testing op amp: no study yet...Please delete this thread
edit : oh maybe it is sine wave but since the gain is huge and above supply then it becomes square wave?
Noticed this before : to get square wave from sine wave : transistor amplifier with large gain to go above supply : output becomes square wave
AnalogKid
Joined Aug 1, 2013
12,256
Not on this planet. First, look up the gain-bandwidth product of a 741, divide that by 1 kHz, and see how much gain is available from the chip. Spoiler - it is not 100,000.
Second, at a gain of 100,000, an input offset voltage error of 45 uV will saturate the output. Compare this to the input offset voltage spec on the datasheet.
So will an input signal level of 45 uV if the input offset voltage error happens to be 0.000000 V. How do you get the signal generator output to be that level?
So will an input bias current error of 45 nA.
I suggest reducing the series feedback resistor to 3.0 K to see if the opamp behaves as expected.
ak
Audioguru
Joined Dec 20, 2007
11,248
The design of a 741 opamp is 53 years old! Why use it today? Kiss it goodbye and bury the old thing.
The 741 opamp design is so old that it will not work with a feedback resistor as high as 10M.
Why are you attempting to get a voltage gain of 10,000 times anyway?
Zeeus
Joined Apr 17, 2019
616
LOL.. This is like the 6th time I'm reading you saying this
Zeeus
Joined Apr 17, 2019
616
Well, meantime, I hope yours is the last time you try to use that opamp.
With Audioguru I learnt a lot about opamps. Instead of counting the above, follow his advice.
Yes.. Understood current source to bias npn then 2 diode drops then PnP from him (or her?)
Going to get chips tomorrow
Just view the lm741 posts similar to this
