Hello all,
I am currently trying to modify a golf trolley control. This is a standard electric golf trolley using 12V 250W Brushed motor.
https://www.amazon.co.uk/Oypla-Headway-Electric-Powered-Digital/dp/B00DC4VWOY
If someone could please shed some lights on the following questions, it will be really helpful. I have attached a picture for visualizing.
1) I want to replace the potentiometer with a thumb throttle. The throttle in the picture is a hall-type throttle, commonly used in e-bikes. Is it possible to replace the pot and control the motor speed with this throttle?
2) As you can see in the image, there is a main handle circuit which basically takes user's input e.g. changing pot to reduce speed, stopping the motor with button etc. I have limited knowledge about circuits. I was wondering if this circuit can be replaced with a Arduino board? This will help me to integrate some additional things such as lcd display, distance counter etc.
Thank you in advance.
