SplitInfinity
- Joined Mar 3, 2013
- 423
As far as a Water Filled Elevator...since a body is suspended in the water as apposed to rising and falling in air where the vast majority of space including the air is empty due to the low mass of the air....the body sits within and upon the water column directly under it.Newtonian physics would say that when you jumped you pushed the elevator away from you (causing more strain on the cables). All the time you are not touching the floor of the elevator, you impart no addition strain on the cables. The cables only have the weight of the elevator on them. When you hit the floor, you again cause additional strain on the cables.
As an example:
Starting position: 500 N on the cable
Jumping up: 700 N on the cable
Off the floor: 300 N on the cable
Landing on the floor: 700 N on the cable
Standing on floor: 500 N on cable
Since our bodies will either be suspended within the water or float upon it...there is no ability for the bodies weight to separate itself from the elevators floor.
Split Infinity
