I agree with your assessment here. I checked values of most of the components in this section of the device. All the component values appear to be reasonably close to expected. There is only one relay associated with the 50 ohm output and it's functioning normally for now. I do have a few spares if it gives trouble in the future.Stuff could have been overloaded and changed value. Those resistance values are low and thus the relay contacts may or may not need to be looked at. Which I said before.
Nice website! I will keep this one bookmarked. I was able to find a replacement that will work in this application from Newark. The only real difference is the new IC has a wider range and a higher frequency limit than the old. Neither will impact the operation in this application.
Not sure I understand this one. Checking voltage to the input should read nothing on DC, but should show the input voltage in AC at approximately 5V. Checking the voltage (power supply) to the chip from the (+) and (-) inputs yields a reading of approximately 29VDC. Is that what you were describing?An OP-amp not used as a comparitor, can USUALLY checked with a voltmeter between the (+) and (-) input. the value measured should be close to zero.
First thing I did. Fortunately the unit in question was being used in a clean environment and is pretty much solid state components. I did check IC seating in the few socket locations, but inspection showed a very clean, minimally abused device.FWIW:
There is always the inspection. You could find a sandwich in a VCR or a roach nest for instance. Cat hair on top of an audio amplifier. Rattles, like an electron tube out of it's socket. regulator for 1 15 kV supply at 1.5A.
Easy to do. I found the issue, therefore the complaint was mine and verified with my scope.Verify the customer's complaint.
I verified voltages, but did not inspect them for ripple. When I get it back on the bench before installing the new chip and resistors, I will check. I didn't think about it as prior to be being damaged, it was a great unit. I don't have an original baseline for how much ripple to expect, so not real sure how much would be too much.Always check the power supplies. Ripple and value. Especially look at the ripple on the negative supplies.
Thanks! I do have a few years under my belt in the field. Unfortunately, our disposable electronics have robbed me of opportunities to actually dig in and repair things like I used to back in the "day"So, far, I think you did well
