glass diodes
Status
Not open for further replies.
DexterMccoy
Joined Feb 19, 2014
429
what does glass diodes do different than black plastic package?
Some glass diodes are germanium, why are they glass?
what is the advantage of glass and what is the disadvantage?
magnet18
Joined Dec 22, 2010
1,227
it's just a different packaging choice, the pros and cons are mostly mechanical
for example, in a vacuum system, glass diodes are preferred because they do not outgass like a plastic would
on the other hand, glass is much more fragile
magnet18
Joined Dec 22, 2010
1,227
I wouldn't say either lasts longer
either could be designed to last centuries of constant operation
there is no "better and longer" for all circumstances, it's a matter of how they are mechanically engineered for the expected environments (in the case of your question, temperature)
38,938
Glass is also essentially perfectly hermetic whereas plastic is not, so glass is preferred in high humidity or wet environments. That's why plastic packages are seldom used in Military or other critical environments.
Status
