A Newark woman went for a mile-long ride under the city of Passaic during Monday's flash flood. She survived the ordeal after being "shot out" into the Passaic River, a result authorities referred to as "miraculous."
Nathalia Bruno, 24 and a driver for DoorDash, was in Passaic on Monday afternoon when she attempted to drive through deep water near High Street and Benson Avenue, said Passaic Fire Chief Patrick Trentacost.
Sometimes your sig line applies perfectly
How'd the peaceful protesters get aboard ship?
My old ship burned near the same pier at that base. Fighting a fire with salt water works but it will destroy everything the fire missed.
I hope not. Looks like she was having a overhaul with all the work-boxes on the flight deck. The smoke looks like a typical low energy combustibles fire in living and work quarters. Unlikely ordinance was onboard and even so it would be locked in the safety magazine deep inside the ship that could be flooded in an emergency.How'd the peaceful protesters get aboard ship?
t's unclear what started the fire. When the fire was first reported Sunday morning, it was said to be in the lower vehicle storage area, Sobeck said, a "huge, open area where you store a lot of marine equipment and everything else."
There is no ordnance on board, Sobeck said, "which was our initial concern" in ensuring safety on and around the ship.
A safety zone has been set up around the ship, he said.
It's unclear what caused the explosion, Sobeck said. Initial reports indicated a "sort of a backdraft," or over-pressurization as the compartment started heating up.
I think it started in a cargo hold.I hope not. Looks like she was having a overhaul with all the work-boxes on the flight deck. The smoke looks like a typical low energy combustibles fire in living and work quarters. Unlikely ordinance was onboard and even so it would be locked in the safety magazine deep inside the ship that could be flooded in an emergency.
That's the usual case for a closed space fire on a ship. A small fire is undetected until it flashes over in a explosion (over-pressure). All sailors are firemen so they know how to handle this type of fire but it's extremely damaging to the ship in most cases because first you need to locate the heart of the fire, build a interior heat barrier by filling up compartments with water on the sides and bottom, then drown the fire after containment on the top. You do this in a dark steel prison, in the heat, in rooms filled with smoke. It's something they practice starting from boot-camp.I think it started in a cargo hold.
What good is a warship without ordnance.There is no ordnance on board, Sobeck said
It's a lot safer to have no ordnance when your ship is being repaired or in non-operational status as this so clearly shows. The white floating ship at the front of the pier is where the crew stays during a overhaul, there are no 24 hour watches checking weapons spaces during repair periods so all weapons are removed from the ship normally.What good is a warship without ordnance.
What you gonna shoot at them....your middle finger?
Brzrkr
Duct tape is insufficient in this case. Bubble gum and a few rubber bands are required for reinforcement.I was impressed with that picture in our news over the weekend. 203,000 metric tons dead displacement. That is big. The George H.W. Bush aircraft carrier is only 100,000 tons.
All they need is a little duct tape.
