Are you sure about 1ma, I'm getting about 10. I=V/R then .095V/10 = 0.0095a = 9.5ma or with the 1 ohm .0098/1 = .0098a = 9.8ma. I can only run to about 50% on the bench but I can run slower. RMS voltage tends to go higher at lower speeds. With the 1 Ohm resistor and PWM in place at 50% 11.9mv at 20% ~13mv. It would just be 10 x that with the 10 ohm resistor.That's only about 1 ma which might be normal.. Using the scope and the 10 ohm shunt in series with the pwm output read the peak voltage across the shunt with the fan running at 90% .
Am I correct in assuming that at 50% duty cycle the RMS voltage would be 1/2 the peak voltage and at 25% the RMS voltage would be 1/4the the peak. In that case, at 50%, the current to the fan controller would be about 24ma, which seams like it would be fine, but at 25% the current would be ~ 52ma which would not be acceptable.
