1) REPLACE the mic and its cable means to remove them. Add a short piece of wire from where the mic output cable was connected and to the circuit ground instead.
2) Put everything inside a grounded metal box.
audio guru i did what you said there are the above following cases in different situation
previously i had connected -ve input to gnd result is same in both
kindly suggest?
