As an amateur radio operator, I completely agree with you, and my post of the chopping block was meant to be a tongue in cheek poke at the idea. I guess it was a little too subtleGenerating pulses like that could severely affect VHF radio reception and would be anti-social if not illegal.
The accepted use of the term refers to the extremely rapid rise time of the broad spectrum radiation from a nuke detonation.As an amateur radio operator, I completely agree with you, and my post of the chopping block was meant to be a tongue in cheek poke at the idea. I guess it was a little too subtle
The use is some experiments and research, study of the effect of EM pulses on certain hardware and the resulting effects.Alec_t said:Generating pulses like that could severely affect VHF radio reception and would be anti-social if not illegal.
I my small experience, even "slow" 2N2369's are probably fast enough for 100Mhz pulses.The 2N2369 also works in avalanche - but you have to select the best part from a quantity.
http://www.aholme.co.uk/Avalanche/Avalanche.htm
Also, go to 5:06 on this video:
And the prequel for the above:
You can find slower transistors if you need a slower rise and fall time.
If you want to trigger it from an external source it is easy...
Avalanche action has been observed since the mid-1950's and work was done to improve the understanding of that mode of operation for the next 40 years.
There probably should be spark gap from tungsten rod where spark will be discharged, and also coil from 1/2" flat copper wire loop that will work as EMP emitter.The 2n3904 circuit typically makes a 35 volt pulse. You can change the amplitude by changing component values and the supply voltage.
I have question to you: what do you have against electromagnetic impulses? It's part of electronics working, and its a science.I have a dumb question on this thread. Why is this one allowed to continue, with even a moderator participating, when all other EMP threads have been closed by said moderators???
