Generate +20/-4 V
ronsimpson
Joined Oct 7, 2019
4,901
This appears to be LTSPICE. You can set the voltage values of 1 and 0. I have set the 1 value to 3.3V or 5.0V or 12V I have not tried setting the 0 value to -4V.
There are good helps for LTSPICE.
WBahn
Joined Mar 31, 2012
33,357
I used your mention method, but the g1 and g2 dead time is asymmetric. How can you change it?
It appears that you are trying to construct a circuit that has a very specific behavior, but doing so by tweaking simulation parameters to get the models to produce the results in the computer that you want. But if you want to then construct a physical circuit that behaves the way you want, you need to do it the other way around. Get the models tweaked so that the simulation results match their actual behaviors and then construct a circuit that, using those reality-based models, does what you need. At that point, you have a fighting chance that the physical circuit will be reasonable close to the simulation results.
ericgibbs
Joined Jan 29, 2010
21,651
hi EM,
The g1 and g2 waveform plots on my simulation are overlapped OK.
BTW: when you post a plot, please add label names to your Nodes, it make it easier to identify on the circuit.
E
Eason Mu
Joined Dec 7, 2024
9
hi EM,
E
Thank you for your help.
I solved this problem. I came across a new problem. Can the half-bridge inverter produce a three-level output? I think not.
