Gear motor alternatives
JAMQ
Joined Aug 29, 2025
9
Hi everyone! Trying to fix my parents' downdraft gear motor but the problem is that the part isn't available anywhere and the company needs 3 months to manufacture the part. Wondering if there are any alternatives?? It's a Wolf ICBDD36I (the gear motor part from Wolf is 813034). I managed to find a part online that's reasonably priced but one of the spades got snapped as it wasn't protected in shipping. Would rather fix it if possible because there are no more reasonably priced motors online. I don't know much about motors but can definitely fit it. Thanks!
35,315
It is not that simple. You have to make sure that you get the motor with the correct voltage, line frequency, and gear ratio.
JAMQ
Joined Aug 29, 2025
9
There doesn't seem to be anything special about the motor, other than the fact that many vendors seem to think it's made of gold, and price it accordingly. Not all of them, though: https://www.shopifysaver.com/detail/384259746135
Hint: I looked up the 3720UP-265 part number for the motor itself to find that listing.
Thanks for the quick reply, I checked the website but it doesn't seem legit. Although the part was right!
JAMQ
Joined Aug 29, 2025
9
I don't really know much about this but is there a way to fix the one I currently have? I know that the specs need to be the same but I'm just trying to find out if there's an alternative for it but haven't been able to so far.
35,315
If the connection to the motor winding is still intact, glue the connection with epoxy or silicone cement.
JAMQ
Joined Aug 29, 2025
9
Yes it is. If you can check the picture it has the copper looking wire still sticking on it. Is that what you mean? I uploaded a closer photo.
35,315
OK. I see the two connectors now. The angle of the bad connector was such that it was not evident.
Just push the connector back into its hole and secure with silicone cement or epoxy cement.
Try not to break the copper wire attached to the spade connector.
JAMQ
Joined Aug 29, 2025
9
Great, will give that a try. Many thanks.
JAMQ
Joined Aug 29, 2025
9
Just did it a few hours ago and it's very solid. Many thanks for the suggestion.
