Hi everyone!
I am designing a buck converter that would charge a battery and planning to use an N type MOSFET on high side and FAN7085_GF085 driver to go with it.
Datasheet:
https://www.fairchildsemi.com/datasheets/FA/FAN7085_GF085.pdf
Application notes:
https://www.fairchildsemi.com/application-notes/AN/AN-9052.pdf
https://www.fairchildsemi.com/application-notes/AN/AN-4171.pdf
If the converter happens to go to discontinuous mode however, the diode stops conducting -> voltage at MOSFET source becomes something >0, and the internal recharge path of FAN7085 activates (as much as I understand it according to the application note 9052, page 2). Doesn't this connect the battery through an inductor to VS pin of the driver circuit (which is connected to the ground at that moment)? What if I put a diode in series with an inductor (like I did in this capture of the schematic)?
Thank you in advance.
Datasheet:
Application notes:
