gate drive for MOSFET
karas
Joined Sep 8, 2011
216
How can i get the negative part of the gate signal
i change the circuit but when it turns off it turn on again go to 5 v
and by lowering R10 to 30ohm is working but this will be too much power consumed from my gate drive chip,is there better way to fix it
AlbertHall
Joined Jun 4, 2014
12,625
There is no R10 and no MOSFET in your circuit o_O
[EDIT] Correction that is so in the attached asc file but the png file shows a different circuit (which also has no MOSFET but does have an R10) but I hadn't spent much time with at as the bottom part of the circuit was cut off.
