Garage Door Safety Sensor Used Independent #2
steve_hoge
Joined Jan 15, 2022
Ran across this thread because I'm interested in using the "Safe-T-Beam" LED/optical sensors that are already wired to my Genie 7055 garage door opener to enable a red/green "Blocked/Clear" light on my garage ceiling that would tell me if I've pulled in far enough to clear the sensors and hence the garage door. Would love to figure out where to tap into the controller's circuit board to intercept this signal and drive a ceiling indicator light without have to build a circuit that decodes the sensor's pulse train itself. Any hints on how to accomplish this? Anyone ever seen an actual schematic for this GDO controller board?
Moderator edit: New thread created from old thread.Genie Garage Door Circuit Board.jpeg
MaxHeadRoom
Joined Jul 18, 2013
30,868
Schematics of proprietary equipment is a rarety and hard to find.
It most likely would be simpler to come up with an alternative method.
Have you considered the windshield/hanging tennis ball method?? :p
28,485
Is there a "blocked/clear LED on the controller already? That would be interesting. Those sensors are part of a rather complex scheme to both announce alignment and detect blockage. As I look at the PCB it seems that there are only two terminals for the four wires from the two sensors. That makes it rather complex. I see two displays on the circuit board. What do they tell you? If one of those is a blocked/clear display the rest is simple.
sghioto
Joined Dec 31, 2017
8,757
That's what I did, definitely low tech but it works great.
:D
Seems like one could place a photocell physically at the red LED and use that as a sensor. Simple transistor circuit with just one LED would duplicate the action of the red LED.
sghioto
Joined Dec 31, 2017
8,757
Curious about my own garage door I looked at the signal across the STB (Safety-T-Beam) connections and saw this waveform.
LM555 as a comparator to switch output with STB signal. Power was supplied by 5 volt USB supply.
No need to tap into the controller board, just need to measure which terminals are plus and minus on the STB.
