Greetings, I have a Gamecube that does not recognize the memory card in slot A but does in slot B. Tested card on another console and it works in A&B. I am trying to identify the two components pictured. I have one pin from the memory card slot that is 3.4v without a card and should drop to 0v with the card in the slot but it stays at 3.4v. Luckily I have a good console to compare the readings to get this information. I could not locate any schematics. The pin from the card leads to these two components. They are labeled DA5 and DA13. On the known good console, when I set the meter to diode mode two of the pins have continuity. The same two pins on the bad console have no continuity. I am guessing the component could be open internally. Any help with identifying the two components would be greatly appreciated. Thank You
