tl;dr I am building a PC inside of a GameCube shell and would like to use the original power button from the GameCube, if you like more info on the build and its progress, see my build thread on SFF Forum. GameCube PC Build
So here is what I need help with, I have the original power button, it is a latching switch (open/closed). With the way my power delivery works I need that switch to control two things. There are two pins on the motherboard that need to jumped momentarily on the rising edge (<250 ms) and two pins that need to jumped the entire time the button is closed. I have 5v power from an internal usb header that supplies current even with the system shut down.
