Thank you. Hey No, This is not a school assignment!I think the gain is clearly spelled out in the datasheet, attached.
Is this a school assignment?
So output voltage is 15 times 100mV ryt? 1.5VThe Texas Instruments datasheet has a graph in figure 12 that shows a gain at low frequencies that would be 15 times (but 18 times at 80MHz) on your non-differential circuit if the input resistors are 50 ohms.
| H | CE Amp Gain | Analog & Mixed-Signal Design | 8 | |
Opamp gain calculation | Homework Help | 15 | |
BJT amp gain | Analog & Mixed-Signal Design | 15 | |
| M | HB100 Doppler radar IF amplifier with MCP6002 for STM32 ADC — gain and filter review | Analog & Mixed-Signal Design | 3 | |
Need a review to my class AB Amplifier design | Homework Help | 4 |
