Gain and Vout calculation
ChipCircuit
Joined May 1, 2023
75
How can I calculate the gain and output voltage of the following circuit?
input voltage =100mV, 25kHz
Differential Amplifier IC= UA733CD
Thank you for your help!
Audioguru again
Joined Oct 21, 2019
6,826
The Texas Instruments datasheet has a graph in figure 12 that shows a gain at low frequencies that would be 15 times (but 18 times at 80MHz) on your non-differential circuit if the input resistors are 50 ohms.
