Fuse for DC-DC step-down buck converter
AlanWalker0131
Joined Jul 15, 2021
5
Hi Everyone!
I'm using this mini buck convert for my car project. The voltage source from my car is 12~13V, and the output from buck converter is around 9.5V to feed the Arduino 12V pin.
So now am thinking to add a fuse to my dc-dc step down buck converter to protect it from electric shock.
May I know how many amps should I use? I have read some forums, some of them suggest to use 3-5A amp fuse? Is it correct?
Thanks in advance!
Best
Alan
AlanWalker0131
Joined Jul 15, 2021
5
I don't think it is necessary to protect yourself from a shock from such a low voltage source.
Hi Papabravo!
Thanks for the reply! I'm actually a bit worried that when we start the engine, the voltage will go up to 14V, not sure if it will cause voltage spike, and kill the dc-dc converter & arduino?
LowQCab
Joined Nov 6, 2012
5,102
Your Arduino-Board probably already has a Buck-Regulator which can handle
substantially more than the 14.5-Volts from your Alternator.
Spike protection is a good idea though.
If You will provide the Data-Sheet for your Arduino-Board
you might get more useful advice about how to protect it.
AlanWalker0131
Joined Jul 15, 2021
5
Hi LowQCab,
Here is the spec of my arduino nano board.
https://www.arduino.cc/en/pmwiki.php?n=Main/ArduinoBoardNano#techspecs
The max input voltage is 12V, I believe if the voltage higher than 12v will kill the board immediately? Lets say, If the voltage spike kill the dc-dc converter, it will feed 13 ~ 14v to my arduino board right?
LowQCab
Joined Nov 6, 2012
5,102
"" Power
The Arduino Nano can be powered via the Mini-B USB connection,
6-20V unregulated external power supply (pin 30), or
5V regulated external power supply (pin 27).
The power source is automatically selected to the highest voltage source. ""
So You have about ~5-Volts of unused Input-Voltage-Capacity,
which in a Car is not all that much,
Car Electrical Systems can be nasty.
A Resistor, a Zener-Diode, and a Capacitor, is all You need to keep it safe.
