dcbingaman
- Joined Jun 30, 2021
- 1,065
To square the circle, simply reduce those 'infinite' number of flat sides reconnecting the remaining ones from the internal gaps created and then grow each infinitesimal one by an infinite amount in such a way that they reach a unity unit , until only 4 equal length ones are left with opposing sides parallel to each otherOne of the "proofs" of infinite series I remember being taught,
there is an infinite number of integer numbers,
there is an infinite number of fractional numbers between each integer,
hence there is two infinites, ( or more
Both statement are true, but both wrong,
the special numbers of infinity, and zero , do not behave as other numbers.
Jenifer ,
how do you square that circle ?
