IC NE 555 TIMER FUNCTIONS
AnalogKid
Joined Aug 1, 2013
12,299
can a temperature control fan using an ne 555 timer project work together with lamp dimmimg project
Yes.
Please fill in these details:
1. Everything there is to know about the fan.
2. Everything there is to know about the 555 timer project.
3. Everything there is to know about the lamp dimming project.
4. What it is that you are trying to do.
ak
sparky 1
Joined Nov 3, 2018
1,218
A temperature control for gpu and cpu fan and can include PWM current control for fan speed. PWM is related.
First is a temperature sensor circuit. A micro controller may or may not be the method.
by searching various key words you can find them
Fan Temperature Controller Module,DC 12V 24V 48V 4-Wire PWM Driver Module for PC Fan/Alarm
28,624
Short answer is YES! Now to discover what it is that you want it to do.
It seems that the fan is used to control a temperature, probably by changing the cooling air flow. And the light dimmer can be used to control the heating provided by the light. Those are my guesses.
