Functionally Sbstitute for PWM controller
picstudent
Joined Feb 3, 2009
92
One of the SMPS I need to Fix has got a Damaged Switcher, 8 Pin IC FA5515
Block diagram below. I cannot get the same part here.
Can Somebody suggest me a substitute for this IC? need not be Pin to pin compatible, I can make some add-on like small PCB and try to connect to this pins. Should not be a big circuit as it will not fit in the available space.
Thank you.
