Full wave rectifier efficiency
22,082
How to calculate the efficiency of full wave rectifier? Also, prove that efficiency of Full wave rectifier is 81.2%
Write the expressions for DC power out and AC Power In. The ratio of those two expression will be the efficiency, just like in all the other cases where you have Power Out < Power IN
38,503
The efficiency depends upon the diode drops at the load current and the AC voltage value . The efficiency is not a fixed value independent of these variables.
22,082
Power Out and Power In can be measured or theoretical. Power out definitely depends on the diode drops.
